Disables command line history expansion.
| cli | Command line interface settings. |
| history | Command history settings. |
| expansion | Substitute occurrences of '!n:w' with the corresponding line 'n' and word 'w+1' from command history (default disabled). |
| session | Configures history expansion for this CLI session only (default ). |
| permanent | Configures history expansion for this CLI session, and all future sessions. |
CLI history expansion is disabled by default.
To view the status of CLI history expansion on the switch, use the show management command.
The following command disables CLI history expansion for this session and all future sessions:
disable cli history expansion permanent
This command was first available in ExtremeXOS 33.1.1.
